66 Pages«<63646566>
Tula3x3
#1281 Posted : Tuesday, April 8, 2025 4:12:13 PM(UTC)
Tula3x3
Russian Federation
good afternoon. is there a complete list of commands with a description of the actions?
MattGrover
#1282 Posted : Monday, April 28, 2025 7:15:02 PM(UTC)
MattGrover
I've got a bit of a recurring issue with UTC losing it's connection to vMix, it's on the same machine, local IP address (127.) for vMix, can't re-sync, and the other day when this happened, even after restarting everything, it still wouldn't connect, it started the day fine though.
Anyone got any ideas why this may be happening?
Cheers
Luis70
#1283 Posted : Monday, April 28, 2025 7:45:13 PM(UTC)
Luis70
Grenada
Was thanked: 8 time(s) in 8 post(s)
UTC seems to a bit troublesome since it is not updated of lately...I use Panel Builder which works much better, plus it is much easier to understand and set up ... you should give Panel Builder a try. ... plus it has a GUI that is more like a real hardware switcher...been using since it was launched, and do not use UTC anymore ...
NoemieM
#1284 Posted : Monday, July 7, 2025 11:31:32 PM(UTC)
NoemieM
Chircanu
#1285 Posted : Thursday, August 7, 2025 5:31:09 PM(UTC)
Chircanu
Congratulations @elgarf on the decision to continue this wonderful project that has made our work easier in our productions. This is the last update. However, I would like to make a small request, namely if it is possible to implement the change of colors from UTC for the rectangle in GT design. Thank you!
https://github.com/elgar...C/releases/tag/v07092025
Chircanu
#1286 Posted : Saturday, August 9, 2025 6:46:15 AM(UTC)
Chircanu
Chircanu
#1287 Posted : Wednesday, August 20, 2025 7:28:17 PM(UTC)
Chircanu
howardsd
#1288 Posted : Thursday, October 30, 2025 3:00:10 AM(UTC)
howardsd
When will we have access to the new version? I saw on One Man Stream where a new version is out. Would love to get my hands on it.
samirbridi
#1289 Posted : Thursday, October 30, 2025 3:16:21 AM(UTC)
samirbridi
Brazil
https://github.com/elgarf/vMixUTC/releases
dips
#1290 Posted : Wednesday, December 31, 2025 2:22:46 PM(UTC)
dips
China
How do I set up this "SetGlobalVariable" and then how is it used? Thank you!
dips
#1291 Posted : Thursday, January 8, 2026 1:10:11 PM(UTC)
dips
China
QQJie Tu 20260108110411.png (93kb) downloaded 233 time(s). QQJie Tu 20260108110455.png (98kb) downloaded 234 time(s).
Where is the error in the format of the expression?
cmsheehan45
#1292 Posted : Wednesday, February 4, 2026 3:01:04 AM(UTC)
cmsheehan45
Hi, thanks so much for UTC and apologies if i am missing this answer anywhere, but with vmix 29 there is 8 keyers now but UTC on exposes 4 keyers. i assume this is the way it is and erhaps fixed in a future release but could anyone confirm? thank you.
rased
#1293 Posted : Monday, February 23, 2026 3:03:06 AM(UTC)
rased
Qatar
The VMix Universal Controller while reload or opening time shows error while loading and apperaring the pop up message to report a bug. please fix this issues as soon as possible.
[img=https://drive.google.com/file/d/1TfkimZsXVBwIC8y9C5tyqLSfDV9GIg56/view?usp=sharing]Error issues[/img]
mikkop
#1294 Posted : Thursday, March 12, 2026 1:36:05 AM(UTC)
mikkop
Finland
Hi
New to the software.
Whats the purpose of the LIVE indicator / button at the bottom of the app?
By clicking it goes from yellow to red but to me it doesnt affect anything.
mikkop
#1295 Posted : Thursday, March 12, 2026 7:03:52 AM(UTC)
mikkop
Finland
Hi
Is there a way to make UTC to automatically sync without clicking the sync button?
If my vMix server reboots for some reason it can automatically open the last position from vMix and also from UTC but it doesnt sync until I click the sync button.
Fernado
#1296 Posted : Saturday, March 14, 2026 10:12:52 AM(UTC)
Fernado
Argentina
Hi everyone. I have a couple of questions about Xpath function in UTC buttons
I want to bring a path I have stored in a title using the xpath function, but it seems that the xpath function doesnt work on filename fields.
The button constructor looks like this:
Command: SetImage
Input & Index
Filename: xpath('vmix/inputs/input[@key="2ba80f44-aa31-43db-b4e9-ba74c639464c"]/text[@index="0"]') <--The path to the image.
In the log tab doesnt show the string in that xpath, just shows the function.
It work with state access functions "_(input[..." but not with xpath. I dont know if isnt implemented or its a bug.
The second question also have to do with using functions to access filenames:
Anyone know if is it possible to concatenate State Access Functions (or xpaths) in one line?
For example:
I have a title with different text fields.
First one its a hidden text with a path "C:\Media\Logos\"
Second one its the name of a team "LAKERS"
It would be cool that if i write something like
Code:
_('Inputs[2ba80f44-aa31-43db-b4e9-ba74c639464c].Elements[0].Text') & _('Inputs[2ba80f44-aa31-43db-b4e9-ba74c639464c].Elements[1].Text') & ".png"
the utc concatenate the 3 string "C:\Media\Logos\LAKERS.png"
I just dont know if its possible and in that case how is the correct syntax.
I hope someone have some info about any of these topics. Thanks!
VMixOJRTV
#1297 Posted : Sunday, March 22, 2026 7:00:53 PM(UTC)
VMixOJRTV
Spain
Saludos, soy usuario de UTC desde hace mucho tiempo, y estoy asombrado de la cantidad de opciones que tiene para simplificar el uso de nuestro proyecto en VMix. Estoy intentando de usarlo en una máquina nueva, y cualquier versión que instalo, al poco tiempo de ser ejecutada, se me cierra. La que estoy usando ahora es la vMixUTC_Donateware.26.03.2023, que es la única que no se cierra. ¿A qué puede ser debido? Muchas gracias por adelantado.
windscar
#1298 Posted : Thursday, March 26, 2026 12:47:08 PM(UTC)
windscar
China
so where can i download the newest version of UTC? can i get the website
jjames
#1299 Posted : Thursday, April 2, 2026 9:46:31 PM(UTC)
jjames
Hungary
Hi guys!
Maybe I write my problem in good place. Is anyone knows, how can I make my language file to work in UTC? I made the file already but it doesnt work :(
thanks for any help!
Pierre Saleh Kandolo
#1300 Posted : Saturday, April 4, 2026 2:38:41 AM(UTC)
Congo, The DRC
vMix has added the number of overlays, but UTC is still stuck at 4 despite the latest update...
Or is there a version already released that I don't have, like the screenshots?
Thanks in advance for your help and guidance.
Capture d'ecran 2026-04-03 183701.png (285kb) downloaded 103 time(s).
Guest (22)
66 Pages«<63646566>
