I'd like to see API calls to control the telestrator.
- Erase All
- Undo
- Change Drawing Color
- Change Font Size
- Change Tool (line drawing, rectangle, circle, etc)
Before enabling the telestrator input I want to make sure that its been reset to the show's defaults.
Joined: 4/23/2017(UTC) Posts: 1,480  Location: Germany Thanks: 3 times Was thanked: 194 time(s) in 174 post(s)
Joined: 9/21/2020(UTC) Posts: 3  Location: Emsland Was thanked: 1 time(s) in 1 post(s)
yes please
Erase is important.
the rest also interesting.
My primary use case for the API is setting up a Stream Deck w/ Companion so that...
1) The producer can ensure the previous telestrator markings are clear before taking the overlay live. 1) The person using the stylus to draw can quickly switch between styles (change color, shape, width, etc).
