TL68
#1 Posted : Wednesday, February 11, 2026 1:32:20 AM(UTC)
TL68
Sweden
Hi!
Working with a setup which is supposed to work for multiple sites, which each have different colors in their graphic profiles.
This setup run on the same data source (google sheets) for title texts, logotype changes etc.
In Sheets I can easily script so a cell changes a color code based on which site the broadcast is running on (when I for example choose which logo to display in another cell in the sheets).
In vMix it would be great if I could change the color on - for example - a title background based on the color code in the data source cell mentioned above. But unfortunately it is not possible.
Workaround now is to use images for color instead. These can be changed in the title editor based on filenames in the datasource which are created with scripting.
But this means extra work creating images when the project template supports 60 sites...
Hope this can be adressed in future updates.
#2 Posted : Wednesday, February 11, 2026 2:09:12 AM(UTC)
Originally Posted by: TL68 Go to Quoted Post
Hi!
Is Possible
But have you tried the rectangle.fillcolor way ?
Screenshot 2026-02-10 172143.png (32kb) downloaded 30 time(s). Screenshot 2026-02-10 172037.png (17kb) downloaded 30 time(s). Screenshot 2026-02-10 172102.png (18kb) downloaded 30 time(s).
TL68
#3 Posted : Wednesday, February 11, 2026 6:12:32 PM(UTC)
TL68
Sweden
Hi!
Is Possible
Hi Doggy!
Thanks for helping! It works fine!
It was my mistake. Had forgot about the settings under "Data" GT designer. So my rectangle had the option "Hidden" checked so I did not see the rectangle.fillcolor option in vMix.
Now it works exactly as I want. Great!
So this thread can be closed.
/T
