Luma key with Mix input impossible?
Joined: 7/6/2021(UTC) Posts: 23   Location: Münster Thanks: 4 times
Hello everybody, Luma key with Mix input seems to be impossible. I chose the input 26 as key-input in Mix2 and then the Mix2 in layer 4 of Nokia What happens here?  Mix Luma Key.png (78kb) downloaded 100 time(s).Thank you
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: MDB  Hello everybody, Luma key with Mix input seems to be impossible. I chose the input 26 as key-input in Mix2 and then the Mix2 in layer 4 of Nokia What happens here?  Mix Luma Key.png (78kb) downloaded 100 time(s).Thank you
Thanks for your answer, but this covers not my case Doing the same with another input works like expected but with the Mix2 it does not work  Luma Key.png (48kb) downloaded 87 time(s).The intention is to do a fade or something like that in the circle
The intention is to do a fade or something like that in the circle Works for me as with any other input. Maybe create a new preset and repeat the steps from scratch. Or post screenshots from your settings & layers.
I realized that the problem is the key source. With a bitmap, it works. But my circle is a mp4-clip and that makes problems. I will try a sequence of pictures next. With a sequence of pictures the key looks good but there is a tiny bright border This is a mix input with output set on Decklink and key-source komp 1_0000.png  015_capture.jpg (56kb) downloaded 37 time(s).And this is the Decklink input and the same key-source  016_capture.jpg (61kb) downloaded 38 time(s).What can I do?
V-Mix support (thanks to Greg) had the solution for both problems
"Please turn off Premultiplied Alpha checkbox on the Mix input under Colour Adjust in input settings. The reason this is needed, is you are doing a straight alpha matte when using luma key, which is not premultiplied.
This option is enabled on Mix inputs as usually the transparent sources going into Mix Input need this to output correctly."
