Systems
Is a separate video card essential on a laptop
Joined: 8/31/2020(UTC) Posts: 35   Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Church I work for is in need of a laptop. The one they have been using is having issues and Im trying to get recommendations. Their budget is limited and Im trying to find something with in their budget. How ever, with Gforce 20xx series recommended and above the prices skyrockets. They are a small church and cannot afford a top end. Wife and I are donating the upgrade from ver22 to the new 29ver.
So Is there a absolute need for a separate video card.
Thanks Rick.
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
yes. you need laptop with separate video card. What is the configuration? How many cameras? 1080p or 4K? capture cards or ip/ndi? budget?
Originally Posted by: Kayo33  yes. you need laptop with separate video card. What is the configuration? How many cameras? 1080p or 4K? capture cards or ip/ndi? budget? 1 camera and 2 microphones ran through a Focusrite Scarlett 2i2 3rd Gen USB Audio Interface for Recording. Very simple set up. Camera is a PTZ that I hoped we could control through the program direct connection but never got it to work. They run 1080p. budget is around 800-900.
I have no control over the budget, Im just consulting for them as a volunteer. I dont attend, I just set up as much as I can on the stream adn do the slides for them to present. Unfortunately, they have chosen a laptop and I hope it will work out It uses a separate video card, but it is an Intel Arc 140v and Intel core 7 Ultra series 2 CPU at 4.8ghz (8 core) has 1 HDMI and 1 Thunderbolt port and 3 3.0usb ports. Ill send them the link to the one you recommend.
The Intel Arc 140v is not a separate video card (dGPU).
It's the integrated GPU (iGPU) of the Intel Core i7 Ultra Series II CPU.
I recommend the Lenovo Legion 5i with ultra 9 275hx cpu / 32gb ddr5 and RTX 5060 (dGPU)
@ w7psk
Although a dedicated NVIDIA GPU is recommended for optimal results with vMix, it will still run with integrated graphics, you are just more likely to encounter performance issues if you try to do too much. Also note, you cannot rely on the boost or turbo speeds on the CPU, you need to look at the base clock speeds of the cores, anything slower than 2.0 GHz is going to struggle with keeping up to the demands of processing LIVE video with software like vMix, and unfortunately, a lot of the newer i7 Ultra Series CPUs have efficient and low power cores much slower than that and so are not recommended for use with vMix.
Well, they went with the one I said dont move to with the integrated video card.
I protested loudly, but they ignored my warning.
well, the main person now says that the new laptop may not work as they thought.
So, I cant help them with that, they need to decide to do what is right sooner or later.
Systems
