fcvideo
#1 Posted : Monday, December 23, 2024 10:48:46 PM(UTC)
fcvideo
You have been a member since:: 5/7/2024(UTC)
I have a streamdeck+, and just starting using the dials to control a few things (well 1....) in VMIX, namely audio levels on different inputs
So I have used the 'SET VOLUME' for the dial, as well as 'AUDIO' for the pressing of the dial, so pressing the dial toggles the audio on and off, turning the dial controls the audio levels when on... All fairly basic stuff (included in description in case someone is trying to work out how to do it....)
but is there a way of displaying the level of audio (I have activator installed to show if on or off) - but the level would be really helpful, as my space does not mean i can have audio mixer displayed)
On the default streamdeck+ setting they do have a % for SD Brightness, and also on Vol Controller, you can see what the output level of an application or system is. Would be great if VMIX could display setting back on the streamdeck display
knbPixels
#2 Posted : Saturday, January 4, 2025 2:50:51 AM(UTC)
knbPixels
I have mine setup so that the little display areas above the knobs show the current volume level for the input they are controlling. You just use the variables in the Button Text String field.
Here's an example of one of mine:
Jim $(vmix:input_jimcamera_volume_linear) Where "jimcamera" is the input name with the space character removed. The result looks like this if that input is set to volume level 65:
Jim
65
fcvideo
#3 Posted : Saturday, January 4, 2025 5:36:54 AM(UTC)
fcvideo
thanks very much for your help.
As it goes, I have been experimenting with Companion over Christmas, and there is a good interaction with VMIX and Companion for this, and so I have an audio meter now showing on the display.
CBallard1231
#4 Posted : Wednesday, January 7, 2026 7:44:31 AM(UTC)
CBallard1231
Jim
65
Sorry for digging this up after 2 years, but can you elaborate on where you're inputing the variables? I played a little with the buttons in the Stream Deck app, but I couldn't get it to do this.
Thanks!
fcvideo
#5 Posted : Saturday, January 10, 2026 3:42:21 AM(UTC)
fcvideo
I ended up using Companion (which I do for nearly all my interactions from Streamdeck to VMIX)
So if using companion, i have set up
Rotate left actions: vmix: Audio - Set Input Volume (decrease by 5)
Rotate right actions: vmix: Audio - Set Input Volume (increase by 5)
with feedbacks:
vmix: Audio - Input Volume Meters
vmix: Audio - Input mute (inverted)
[img=https://drive.google.com/file/d/1bIz459hEF_x80l6S2Ct1aSoZSq6VYY7o/view?usp=drive_link]Screenshot[/img]
[img=https://drive.google.com/file/d/1laUBKYI8r5_f7fVyynEnexX8gOy71qHJ/view?usp=drive_link]Screenshot[/img]
CBallard1231
#6 Posted : Tuesday, January 13, 2026 2:09:45 AM(UTC)
CBallard1231
with feedbacks:
Thanks! Unfortunately due to security reasons at my place of business, I can't use, or even install Companion on our devices. It's not vital that I have it, its just a plus if it could work.
