televisiontim
#1 Posted : Thursday, January 8, 2026 11:03:07 AM(UTC)
televisiontim
Looking for a way when transitioning (dissolve or cut) to have an overlay turn off automatically. For example, during the production we are switching between different cameras with the same lower third (static) but when we go to a source that is a presentation (PowerPoint) the overlay needs to turn off. Yes I know it can be done manually but it's never timed correctly to make it look clean. It's great that an overlay can be placed in preview which results in a nice clean transition that adds the overlay, but can this be done in opposite that removes it?
NoemieM
#2 Posted : Thursday, January 8, 2026 7:18:54 PM(UTC)
NoemieM
Could a trigger on your presentation input do the work ? On your presentation input, you create a trigger "On transition In" > OverlayXOff ? And you make a second trigger "On Transition Out" > OverlayXOn so when you exit your presentation your title comes back automatically.
Hope this helps,
thanks 1 user thanked NoemieM for this useful post.
televisiontim on 1/9/2026(UTC)
televisiontim
#3 Posted : Friday, January 9, 2026 12:29:10 AM(UTC)
televisiontim
Great idea and it's works, THANKS!
Glactiond
#4 Posted : Tuesday, June 16, 2026 6:08:38 PM(UTC)
Glactiond
Add a Trigger to the presentation input that fires when it goes live:
Input Settings → Triggers
Event: OnTransitionIn (or OnStart)
Action: OverlayOff (select the overlay channel)
This will automatically remove the lower third when you transition to the PowerPoint source.
