bulent_atlas
#1 Posted : Monday, December 8, 2025 4:46:20 PM(UTC)
bulent_atlas
Turkey
Hi vMix Team and Community,
I am currently developing a custom hardware Tally Light system using Arduino. My goal is to provide visual feedback not just for "On Air" (Red), but also for "Connection Warning/Error" (Yellow/Flashing) situations so the operator can be alerted immediately without looking at the statistics window.
The Problem: I have analyzed the api.xml output (even in the latest versions), and currently, it only provides the boolean state of the activity. For example: <streaming>True</streaming> or <recording>True</recording>.
However, the XML output completely lacks "Health Statistics" such as:
Dropped Frames count
Current Bitrate / Buffer status
SRT RTT or Lost Packets
Because this data is missing from the API, I cannot program my external tally to flash yellow when the stream is unstable or when the recording drops frames due to disk overload.
The Request: Could you please consider adding a <statistics> node or attributes to the existing XML API for Streaming, Recording, and SRT Outputs?
Ideally, we need access to:
Streaming: Dropped frames count & buffer health.
Recording: Dropped frames count & disk write errors.
SRT: Connection quality stats (RTT, dropped packets).
This feature would be incredibly useful for studios building custom automation and monitoring tools.
Thank you for your hard work and this amazing software!
Best regards.
ranjandxb
#2 Posted : Friday, January 2, 2026 9:37:04 AM(UTC)
ranjandxb
+1
ggudnason
#3 Posted : Saturday, January 3, 2026 4:59:59 AM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
+1
jet
#4 Posted : Sunday, January 4, 2026 5:25:41 AM(UTC)
jet
Was thanked: 24 time(s) in 22 post(s)
+1
jip
#5 Posted : Monday, January 5, 2026 7:42:27 AM(UTC)
jip
Estonia
+1
+ include camera and NDI input statistics, e.g. for automatic monitoring of NDI connections
Roy Sinclair
#6 Posted : Thursday, January 15, 2026 8:04:39 AM(UTC)
Roy Sinclair
Was thanked: 31 time(s) in 27 post(s)
+1 Having a program watching key statistics and letting you know their are problems developing would allow advance warning for some developing problems, maybe even enough warning to avoid some catastrophes.
Kotin
#7 Posted : Saturday, April 11, 2026 4:25:02 AM(UTC)
Kotin
+1
bwalz
#8 Posted : Thursday, May 7, 2026 7:32:03 AM(UTC)
bwalz
Germany
For an SRT Stream at least the following metrics should be exposed by the sender:
  • rtt_ms — Network latency / round-trip time
  • packet_loss_percent — Indicates network quality
  • retransmitted_packets — Shows how many packets had to be resent
  • dropped_packets — Detects unrecoverable transmission problems
  • buffer_fill_percent — Helps identify sender congestion
  • send_rate_mbps — Actual outgoing bitrate
  • estimated_link_capacity_mbps — SRT bandwidth estimation
  • flight_size_packets — Amount of in-flight data
  • flow_window_packets — Current congestion/window size
The statistics should follow the definitions defined in the GitHub SRT Documentation.
KerryDP
#9 Posted : Thursday, July 9, 2026 8:51:29 AM(UTC)
KerryDP
New Zealand
Absolutely want this. I need to be able to tell a remote decoder/production hub the stream status of the Vmix encoder, including target IP address & port number, bitrate, retransmitted packets etc.
In general, let's make all Vmix statistics available via the API.
mikael_g
#10 Posted : Thursday, July 30, 2026 7:16:57 PM(UTC)
mikael_g
Norway
+1
Ive been trying to figure out a problem with our setup and really wanted to log the amount of frames dropped and send alerts to myself when the rate got to high. Assumed at first this would be in the API. Really hoping it makes it into the API soon.
Guest (5)
