Feature Requests
API Control for SRT Output set Mode, IP and Port
I'm writing to ask if, in upcoming updates, you are considering adding API functionality to allow dynamic modification of the stream mode, IP, and port-similar to how it's already possible to change the RTMP destination and streamkey via the API. This feature would be extremely useful for automating stream target changes on the fly.
Joined: 2/23/2023(UTC) Posts: 73  Thanks: 20 times Was thanked: 11 time(s) in 4 post(s)
Joined: 3/21/2022(UTC) Posts: 47  Thanks: 1 times Was thanked: 9 time(s) in 9 post(s)
Originally Posted by: PauMedia  I'm writing to ask if, in upcoming updates, you are considering adding API functionality to allow dynamic modification of the stream mode, IP, and port-similar to how it's already possible to change the RTMP destination and streamkey via the API. This feature would be extremely useful for automating stream target changes on the fly. Stream handling improvement would be great: - Access Stream Parameters from API both read/write for RTMP and (important) SRT as well.
- Have presets for SRT Streams which are quick to change within the GUI but also from scripts and using the API. This would help a lot when a live gig requires handling several streams both at the same time and/or sequentially.
- Have triggers on stream start and signal loss
- Have a "Stream Manager" dialog window similar to the audio bus manager where you can manage all things stream, see whats active and the current operational parameters.
Thanks, Christian
Joined: 4/23/2017(UTC) Posts: 1,420  Location: Germany Thanks: 3 times Was thanked: 189 time(s) in 169 post(s)
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 97 time(s) in 93 post(s)
Joined: 12/8/2022(UTC) Posts: 108  Thanks: 31 times Was thanked: 1 time(s) in 1 post(s)
+1000!
...and also please make it possible to use data source data to populate the settings for SRT IP, Port, Latency etc.
EDIT: Ooops. Misread title. I see this thread is about SRT output. I am wishing for the same functions but for SRT input streams. Will post a specific request for this.
Joined: 4/28/2019(UTC) Posts: 12  Location: Salem, Oregon Was thanked: 2 time(s) in 2 post(s)
Joined: 11/14/2012(UTC) Posts: 310  Location: Finland Thanks: 195 times Was thanked: 19 time(s) in 17 post(s)
Joined: 1/25/2019(UTC) Posts: 327  Thanks: 22 times Was thanked: 82 time(s) in 62 post(s)
Thanks: 4 times Was thanked: 8 time(s) in 7 post(s)
Feature Requests
