Hardware Compatibility
HELP! I need to connect 8 logitech brio 4k cameras
I need to connect 8 logitech brio 4k cameras, what do you recommend? So far I have thought:
Motherboard Asus X670-p Ryzen 9 7950x3d 64GB Ram DDR5 Kinston or Corsair. Nvidia RTX 4090 video card 2TB NVME drive, minimum 32000 megabyte per second Two X300 4Tb disks each for raid 850w source certified 80 plus, I recommend thermaltake or corsiar Cool be quiet! Dark Rock Pro 4, BK022 Corsair Carbide Spec Delta cabinet or similar
You will use up all of the USB bandwidth in your system by attempting to connect 8 Logitech BRIO cameras. Think about getting an internal capture card before you buy 8 BRIO cams.
Originally Posted by: SportsNetUSA.net  You will use up all of the USB bandwidth in your system by attempting to connect 8 Logitech BRIO cameras. Think about getting an internal capture card before you buy 8 BRIO cams. But the logitech brio go by USB. How do I connect them by capture?
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Originally Posted by: ElianYmanol  I need to connect 8 logitech brio 4k cameras, what do you recommend? So far I have thought:
Motherboard Asus X670-p Ryzen 9 7950x3d 64GB Ram DDR5 Kinston or Corsair. Nvidia RTX 4090 video card 2TB NVME drive, minimum 32000 megabyte per second Two X300 4Tb disks each for raid 850w source certified 80 plus, I recommend thermaltake or corsiar Cool be quiet! Dark Rock Pro 4, BK022 Corsair Carbide Spec Delta cabinet or similar I see this discussion is a few years old, but since I had considered a similar setup (I've since moved on to other things), I'll share my idea; perhaps it will help others.
Starting with an AM5 platform and following vmix's recommendations regarding PCIe CPU lanes,
here's a configuration for USB cameras, optimizing the setup suggested by ElianYmanol:
It combines a Ryzen 9 9950x (24 PCIe lanes + 4 USB 10Gbps ports)and a 4-port USB Type-C USB 3.0 5Gbps PCIe card (Features 4x USB independent controllers)
installed on an Asus ROG Strix X670E E-gaming motherboard, which, according to its block diagram, can distribute the PCIe CPU lanes as follows:PCIe 1 = x8 = GPU PCIe 2 = x4 = 4 USB ports Type-C USB 3.0 5Gbps PCIe Card (Features 4x USB independent controllers) m2_1 = x4 = m2 SSD m2_2 = x4 = m2 SSD m2_3 = x4 = m2 SSD 3 x 10Gbps USB ports
Knowing that the Brio 4K operates on USB 3.0 for 4K30p
by implementing the following setup, it would be possible to have 8 x Brio 4K at 4K30p AM5 - 8 x usb 4k30p.png (1,927kb) downloaded 12 time(s).by installing a 4-Port USB Type-C USB 3.2 10Gbps PCIe Card (Features 4x USB independent controllers)
and using 10Gbps USB hubs while respecting the bandwidth of the USB ports
it would "theoretically" be possible to have 14 x Brio 4K on this configuration USB AM5 -14 x 4k30p.png (2,058kb) downloaded 14 time(s).all this is just theory
because I think that in practice, the system will surely reach its limits after a certain number of uses Cameras
This can only be verified through real-world testing, but I think a number of cameras could work.
 1 user thanked Kayo33 for this useful post.
