Struggling to stream to youtube in 4k
I am struggling with streaming to youtube in 4k. I have it set to stream with H264 2160p 30mbps and the stream usually starts out fine, then in a short time the stream button will start flashing that something is wrong, but no actual error message pops up. The Gpu and CPU usage are both under 50%. My bandwidth is not an issue either, I have 1Gbps upload. I have tried messing around with different settings but to no avail. If I drop it to 1080p it works fine. I just don't know where to go from here haha.
Thanks.
Joined: 1/22/2021(UTC) Posts: 3   Location: Rio de Janeiro
Thanks. hi, Is your internet cable, fiber, or satellite? This problem seems to be with your internet provider. I have the same problem here in my studio; whenever I'm streaming at night, even with 100MB upload speed, sometimes the transmission drops to zero, freezing the image. But if it's during the day, I can usually do a good stream.
Thanks. hi, Is your internet cable, fiber, or satellite? This problem seems to be with your internet provider. I have the same problem here in my studio; whenever I'm streaming at night, even with 100MB upload speed, sometimes the transmission drops to zero, freezing the image. But if it's during the day, I can usually do a good stream. Fiber, Internet has been tested and is good.
