LeChatFantome
#1 Posted : Sunday, November 23, 2025 1:46:47 PM(UTC)
LeChatFantome
Switzerland
I’m having trouble controlling a Virtual Set from Bitfocus Companion, even though everything works fine locally inside vMix.
Setup
vMix on Windows 11
Bitfocus Companion (vMix module over TCP is working: I can control layers, tally, etc.)
I’m using a custom Virtual Set with a config like this:
<virtualSet>
<input name="Background" x="0" y="0" zoomX="1" zoomY="1" rotateX="0" rotateY="0" rotateZ="0" dynamic="True" />
<input name="Layer1" x="-0.667" y="0.667" zoomX="0.33325" zoomY="0.33325" rotateX="0" rotateY="0" rotateZ="0" dynamic="True" />
<input name="Layer9" x="0.667" y="-0.667" zoomX="0.33325" zoomY="0.33325" rotateX="0" rotateY="0" rotateZ="0" dynamic="True" />
<!-- 4 zoom presets -->
<zoom name="1" x="0" y="0" zoomX="1" zoomY="1" />
<zoom name="2" x="0" y="0" zoomX="3" zoomY="3" />
<zoom name="3" x="2" y="-2" zoomX="3" zoomY="3" />
<zoom name="4" x="-2" y="-2" zoomX="3" zoomY="3" />
</virtualSet>
In vMix, this input shows up as Virtual, with a name like 277 CV X1.[ID] [Name]
What works
In Settings → Shortcuts, if I create a shortcut:
Function: SelectIndex
Input: 277 CV X1
Virtual Set Zoom / Value: 1 (or 2, 3, 4)
then pressing the assigned keyboard key correctly changes the zoom preset of the Virtual Set.
So SelectIndex is definitely working in vMix for this input.
What doesn’t work
From Companion, I cannot get this same SelectIndex to trigger via TCP.
The vMix module is connected (I already control other things like layers, tally, etc.).
Using the action “vMix: Scripting – Run custom command”, I tried several commands, for example:
SelectIndex&Input=277&Value=1
SelectIndex&Input="CV X1"&Value=1
and a few similar variations.
None of these attempts change the Virtual Set at all, while the internal vMix keyboard shortcuts do.
I can work around this by using vMix shortcuts plus the Companion “Shortcut – Press” action, but I’d really like to understand the proper way to send SelectIndex to a Virtual Set via the TCP FUNCTION API.
My questions
What is the exact syntax to call SelectIndex on a Virtual Set via the TCP FUNCTION command?
(e.g. FUNCTION ??? Input=??? Value=???)
Are there any special considerations when using custom Virtual Sets (created from config.xml) compared to the built-in ones?
Are there any known limitations related to input numbers (e.g. over 300) when using SelectIndex through the API?
Thanks a lot for any help, and I can provide screenshots or the full config.xml if needed.
Cat
dmwkr
#2 Posted : Sunday, November 23, 2025 6:17:14 PM(UTC)
dmwkr
IIRC, the correct syntax for the TCP API and custom commands is with a space instead of the ampersand between the function and the first parameter, i.e.
Code:
SelectIndex Input=277&Value=1
thanks 1 user thanked dmwkr for this useful post.
LeChatFantome on 11/23/2025(UTC)
LeChatFantome
#3 Posted : Sunday, November 23, 2025 11:47:49 PM(UTC)
LeChatFantome
Switzerland
Code:
Thanks a lot for the help, that was exactly the missing piece!
The correct TCP command format is:
SelectIndex Input=277&Value=2 (note the space between SelectIndex and Input).
I had been trying other syntaxes for a while, so this clarification really saved me a lot of time.
Everything is now working perfectly from Companion to vMix. 🙏
