Archer01
#1 Posted : Thursday, November 13, 2025 9:53:41 PM(UTC)
Archer01
I’ve been working with SRT links for years in studios and headend environments, and recently I came across something quite interesting that I thought might be useful to share here.
When you feed an unstable SRT input (bitrate spikes, packet loss, jitter, etc.) into a gateway and repeat it as UDP/RTP multicast without any remuxing at all, the multicast output stays surprisingly stable — even when the SRT input is suffering short periods of 8–12% packet loss.
As long as SRT manages to recover the missing packets within the buffer delay, the UDP/RTP output remains clean and unaffected.
No added latency, no TS modifications, no glitches.
I tested this across multiple setups (including a multi-NIC on-prem system we use for some cable headends) and got the same result every time:
The multicast side receives a perfectly solid stream even while the input SRT looks like it’s “fighting for survival”.
So I’m curious:
Has anyone else here noticed this kind of behavior?
Do you rely on SRT recovery to protect your multicast distribution layer?
Do you use dedicated SRT→UDP gateways, or feed SRT directly into your decoders?
Interested to hear real-world experiences from people running SRT contribution/distribution in production.
BARP
#2 Posted : Monday, November 17, 2025 10:04:44 AM(UTC)
BARP
Yes, we regularly adjust our SRT latency to compensate for challenging last-mile connectivity, especially when utilizing bonded cellular as our backup network. Increasing our latency setting to 5,000ms (5 seconds) has been able to overcome even 20-25% packet loss across 4 to 6 bonded 5G modems. We send all of our feeds into a Haivision SRT gateway and distribute out from there for contribution, confidence return, etc.
