hi is there a way to do 2 replays, so one full screen and then a picture in picture. so im trying to do this so i can do replays of sporting events and have main cam full screen and a go pro (secondly cams) corner/ goal cams put in top corner of the screen both playing at the same time? cheers
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: samr321  hi is there a way to do 2 replays, so one full screen and then a picture in picture. so im trying to do this so i can do replays of sporting events and have main cam full screen and a go pro (secondly cams) corner/ goal cams put in top corner of the screen both playing at the same time? cheers Sure you can, just add your replayB as layer to your replayA
