NDI
Turning on NDI from Streamdeck/Companion
Joined: 5/7/2024(UTC) Posts: 21  Thanks: 5 times Was thanked: 3 time(s) in 2 post(s)
Hello all
I am using companion, and also use some times NDI, but not all the time, so it is normally off
I have set up Companion Feedbacks (onto Streamdeck) to show if NDI 1 is on - but is there a function (or command) to turn on NDI (or toggle NDI on/off)?
Have looked in 'Unofficial vMix API Reference' as well as google, and cant see it. Only NDI commands I can see are NDICommand (which seems more like setting outputs, but cant even get that to work), NDI Select Source & NDI Recording
Any help appreciated - thanks
Lee
Lee Just leave NDI On, its def not using any bandwidth if one is not viewing it or is an active input
NDI
