ssl4000g
#1 Posted : Thursday, November 6, 2025 6:06:25 AM(UTC)
ssl4000g
I am on vMix 29.0.0.6 and grabbed the Zoom plugin installer. When I click on the installer, nothing happens. When i choose Run as Administrator, I get the splash screen and nothing happens.
Has anyone seen this behavior and have a solution?
On a Dell XPS 15. Which does have some Dell bloatware on it. I have found that the bloatware gets in the way of vMix updates and requires some McGuyvering to get around. This could be my issue, but wanted to check if this has happened to others before I go deeper.
Thanks for any help. Searching the forum didn't produce any results specific to my question.
W
chris_foxsports
#2 Posted : Tuesday, November 11, 2025 9:25:01 AM(UTC)
chris_foxsports
I am experiencing the same issue. Using Windows 11 Pro for Workstations 26100.6899 on a Dell Precision 3930. Did not experience this issue before the upgrade to Windows 11 on the same machine. Talking to support now, but have yet to be successful. Hopefully they'll come up with something that works and I can update, but it is quite frustrating.
ssl4000g
#3 Posted : Wednesday, November 12, 2025 12:37:53 AM(UTC)
ssl4000g
If you would Chris, post back with an update. I've experienced some file access issues with vMix updates prior to Win11 as well. I dug a little deeper and am looking into my laptop setup. It is a managed device setup by out IT department. It supposedly allows access to any and all software updates. Have to setup a meeting with one of our IT folks to get clarity on that.
W
