Clint Cruz
#1 Posted : Wednesday, November 5, 2025 6:55:40 PM(UTC)
Clint Cruz
I have a Title that I have tied a google sheets of data on. I want to be able to use the data as an animated slide show.
i would like it to pause for 10 seconds, and in the output view, the output view would show the transition animation and data. Once the 10 seconds is completed, then go to the datasource would move to next row of data and show the animation and data on the output view.
currently, I activated Loop and the Auto Next in the Data Sources, but as i do this, the output view only did the first row of information, then the following just shows the data and skips the animation. How can i make it work so that i still have the Title Transition Animation and also loop to the top of my datasource list after the completion of all the rows?
#2 Posted : Wednesday, November 5, 2025 8:10:03 PM(UTC)
One can program in animations within the title designer using the "DatachangeIn/Out" options
#3 Posted : Wednesday, November 5, 2025 9:33:41 PM(UTC)
@ Clint Cruz
Sounds like you just want the Title to restart every 10 seconds but with new data.
You could easily do this with the PlayList, Overlay Settings and a Trigger.
- Set the Playlist to Overlay the Title for 10 seconds or so and then "Loop"
- Set your desired Overlay channel "Duration" to 7 or 8 seconds in Overlay Settings
- Set an "OnOverlayOut" Trigger on the Title to advance to the next Data Source row
Clint Cruz
#4 Posted : Thursday, November 6, 2025 6:09:28 AM(UTC)
Clint Cruz
Ice,
thank you for the suggestion. I did run into a problem. ONce the Datasource reached the end of the table, how do you advance to the beginning row of the Datasource? its stuck at the last row of the data and wont loop.
Clint
#5 Posted : Thursday, November 6, 2025 8:38:37 PM(UTC)
@ Clint Cruz
You could forgo the Trigger and set the Data Source Manager to "Auto Next" every 10 seconds and then "Loop", but getting the timing right might be tricky when starting the Playlist.
