Feature Requests
Setting for default audio device when adding Camera Inputs
Joined: 2/18/2014(UTC) Posts: 1,812 Location: Stockholm
Thanks: 137 times Was thanked: 292 time(s) in 246 post(s)
We use the video from a lot of cameras, but never their audio. I know that a lot of users take external audio in via one (1) of the camera inputs. And I can for sure imagine that some users actually switch audio source when another camera input is output (auto mixing). So there is of course a need to be able to specify audio devices for camera inputs. The problem, for at least us, is that we always have to select "None" when adding/changing camera inputs.
I suggest a new Setting/Audio named "New Input's default audio device" with two options: - None - Device specific This also implies that if a input is changed, it's audio device should remain (one could easily select another one if needed.
Feature Requests
