arszu
#1 Posted : Saturday, November 1, 2025 7:31:53 AM(UTC)
arszu
Poland
Witch Motherboard for AMD RYZEN 7 9700X?
Is it possible to have two capture cards?
Pcie x8
And
Pcie x4?
All connected to cpu?
Kayo33
#2 Posted : Saturday, November 1, 2025 9:09:25 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
E-ATX :
MSI Meg x670e Ace (pcie x8 + pcie x4)
https://pl.msi.com/Motherboard/MEG-X670E-ACE
ATX :
Asus ProArt B650-CREATOR (pcie x8 + pcie x4 card via riser m2 to pcie x4 on m2_2 port)
https://www.asus.com/fr/...t-b650-creator/techspec/
Asus Proart x670e Creator (pcie x8 + pcie x4 card via riser m2 to pcie x4 on m2_2 port)
https://www.asus.com/fr/...e-creator-wifi/techspec/
Asus Proart x870e Creator (pcie x8 + pcie x4 card via pcie/tb4 enclosure / not use port m2_2)
You can even add 1 or 2 additional PCIe x4 cards if the PCIe/TB4 enclosure has multiple PCIe slots, like the Sonnet Echo Express SE IIIe.
Here are the different configurations for using GPU (x8) and two capture cards (x8 + x4) on the 24 PCIe CPU lanes of the AM5 platform.
Other motherboard models may support these configurations.
Consult the motherboard manuals before purchasing.
arszu
#3 Posted : Sunday, November 2, 2025 8:52:18 PM(UTC)
arszu
Poland
You're awsome!
Guest (5)
