Feature Requests
External Video Output Audio as Selectable Audio input
Joined: 10/9/2018(UTC) Posts: 28   Location: Leesburg AL Thanks: 1 times Was thanked: 2 time(s) in 2 post(s)
When using External Video outputs, they all show up as webcam inputs in programs like skype and webapps like StreamYard Etc.
Camera Inputs [img]https://imgur.com/RxWDKt4[/img]
vMix External Video as Inputs [img]https://imgur.com/8fwE38o[/img]
But what we do not see is a matching source for each of these external outputs as audio sources.
Audio Inputs, no vmix options [img]https://imgur.com/0hVRPzU[/img]
If this was possible, there would be no need for NDI Tools or Virtual Cable (as you can see I am using) to get the audio needed.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
it is very easy to change the audio input to the output - change the bus in the external setup and routing the audio input to the audio bis - you have 8 stereo bus for this.
Originally Posted by: Kay  it is very easy to change the audio input to the output - change the bus in the external setup and routing the audio input to the audio bis - you have 8 stereo bus for this. I think you miss understand the issue here, as I showed above, when using a web based service like Stream Yard or evMux, the vmix audio sources do not appear on the selectable list like the video outputs do. This requires the use of either virtual cable and or NDI Virtual web cam in order to use the audio source.
Feature Requests
