Instant Replay
Need Help About InstantReplay
Hello please keep in mind that im new at Vmix. The problem is im using avmatrix uc1218 capturecard and vmix 28.0.0.43 version. Im plugging my gopro and adding an camera input at vmix set to 1280x720 25p and creating an instantreplay input is set to 1280x720 25p. Whenever i try to start instantreplay recording, vmix gives an error that says "one or more cameras recordings has failed.Check the log for details. "ReplayTick". Whatever i tried i couldnt fix it. Any suggestions or helps?
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
maybe change format camera input to MJPG or H264 low latency
thanks for the tip i figured it by formatting my pc. now everything is okey instead of replay record. replay is not working at 1280x720p says vmix replay selected video recording format is not supported
Instant Replay
