Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Has anyone already created working OMT Raspi images? I've tried, but after selecting the source, I don't get an image. So if anyone would be willing to provide the two (or one combined) OMT Raspi projects as an image, that would be great. (player and sender) Thanks P.
Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4790 time(s) in 1644 post(s)
What does the log say on the web server after selecting a source?
I am having a similar issue. After I choose a source the web page log shows : 'Receive.NoFrame'
Receive.NoFrame usually means it is unable to connect to the source. So I would suggest general network diagnostics such as: a) ensure device is on the same network / IP range as the OMT source b) check that there isn't a firewall blocking access to the OMT app on the sending machine. c) check that some other app/pc can access the source fine (such as Windows running vMix, OBS with the OMT plugin etc)
Also double check to make sure the build steps are followed exactly in the guide. For example if everything is working correctly you should have libvmx.so file in the same folder as the app, if libvmx is missing then it cannot decode the frames.
Thank you, I tried another PC as source and it is working correctly. Have you release the case print files?
The documentation for both Raspberry Pi examples has just been updated to make the installation process much more clearer, as some not so obvious steps were missed!
We're still busy working on some issues with the 3d printed case models, but will release that as soon as it is ready.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Hello, Maybe I misunderstood, but where can I find an image or procedure to install OMT on a Raspberry Pi? I'd like to create a turnkey solution on a Raspberry Pi to connect USB cameras to it.
Originally Posted by: admin  https://github.com/openmediatransport/omtcapture Thanks a lot 👌
