2 vmix instances to make more zoom guests available via NDI on the network?
Joined: 10/24/2023(UTC) Posts: 25   Location: Südtirol Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
I am currently preparing a new show series in which several guests will be connected via Zoom. The virtual set of the show will be rendered in an external system and the guests will be displayed there in their own virtual areas (see example image with one remote guest). Since vMix (even in version 29) only supports four NDI outputs, I am looking for a way to get multiple guests into the renderer via NDI. If possible, I would like to avoid using a solution from another manufacturer, as this would make the setup more complex (e.g., different latencies, more complex audio routing, etc.). My first thought was to use one or more PCs with vMix, which in turn are connected to Zoom and provide additional NDI streams. The audio and guests in full-screen mode are processed by the primary vMix instance. - Has anyone tried this before? - Does the Zoom API even allow this? I am open to further suggestions that ensure a clean and stable setup. Thanks in advance to the community!  studio guest example (Klein).png (490kb) downloaded 51 time(s). Aximmetry_Studio_Beispiel_Gaeste.jpg (223kb) downloaded 139 time(s).
Joined: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
Originally Posted by: mavik  Thanks for the input @mavic, but the problem remains that there are only four outputs in total. In addition, output 1 is reserved for the program and, for example, as a stream for the zoom guests. That leaves only three outputs. I usually use a second output as a studio monitor (mix), which I can use to show the presenter all the necessary information. That would leave only two. Or am I overlooking a function somewhere? I know that vMix Call can provide multiple outputs, but experience has shown that our guests often couldn't handle this solution.
Maybe I have misinterpreted your point. But what I'm saying is that you can have an output for every input in vMix when you enable it. For zoom/teams meetings, you can extract individual participants over NDI directly from the App as well. Completely outside of vMix.
