maej
#1 Posted : Thursday, October 23, 2025 1:18:36 AM(UTC)
maej
After upgrading from vMix 29.0.0.25 to 29.0.0.33, I started seeing a solid green screen on all video inputs—including intros, outros, and camera feeds on my NVIDIA GPU system.
Audio played normally, but the video output (both Preview and Program) was completely green, even while live streaming.
Affected Areas
MP4 intros/outros (H.264 encoded)
NDI and camera inputs
Virtual sets and chroma key layers
Cause (Based on Testing)
This appears to be related to changes in hardware decoding and DirectX rendering introduced in build 29.0.33.
While my AMD GPU system runs 29.0.33 with no problems, my NVIDIA GPU system shows green video across all inputs.
That suggests the issue is linked to NVIDIA’s driver interaction with vMix 29.0.33’s new video decoding path.
#2 Posted : Thursday, October 23, 2025 1:44:10 AM(UTC)
Was thanked: 4733 time(s) in 1623 post(s)
So this is very strange. Your second post appears to be AI generated as it refers to settings that have never existed in vMix.
I am going to give the benefit of the doubt and assume that was some kind of mistake, but have to delete the post due to the potential for confusion for other users.
As for the issue you mentioned, this is absolutely not caused by anything in vMix 29.0.0.33 as there have been zero changes in the graphics pipeline since the versions you mentioned.
What is far more likely is the vMix update you did was not installed correctly due to programs still running on the system.
The symptoms of this are green inputs, due to the correct files not being available.
The fix for this is simple, restart the computer, make sure every program is closed, including background programs like Zoom and then install the latest vMix again.
sinc747 on 10/23/2025(UTC)
