Hello I'm extracting data in an XML file via datasource . I'm pasting it into the statistik.gtzip caption in the last name (last name first name) field. I need a script that will swap last name first name with first name last name.The text field where the last name and first name are displayed in this caption is called FIRST.txt. Please help, I'm a complete noob. I've spent the whole day trying to figure this out, but I still can't get it working. Even the AI suggestions didn't help.
Originally Posted by: vadimtv  Hello I'm extracting data in an XML file via datasource . I'm pasting it into the statistik.gtzip caption in the last name (last name first name) field. I need a script that will swap last name first name with first name last name.The text field where the last name and first name are displayed in this caption is called FIRST.txt. Please help, I'm a complete noob. I've spent the whole day trying to figure this out, but I still can't get it working. Even the AI suggestions didn't help. Just switch the mapping between the title field and the datasource references
<PersonID>21561</PersonID> <PersonName1>FAKHRITDINOV Sergey</PersonName1>
This data appears in XML format. DataSource defines it as a single row (one text field (FAKHRITDINOV Sergey)). The statistic caption shows it as a single text field. I'm not allowed to make changes to the XML file
Originally Posted by: vadimtv  <PersonID>21561</PersonID> <PersonName1>FAKHRITDINOV Sergey</PersonName1>
ok i misunderstood just like AI did first you will have to retrieve the name through a title (examples in he "scripting for dummies" post) than you can split up the name and concatenate them in reverse order and put them in your title https://www.google.com/s...ceid=chrome&ie=UTF-8some names might cause problems though
