Hi, as the vMix screen is configured to view the video windows on one side and the other side the audio  Thank you! Esteban.
Joined: 8/2/2013(UTC) Posts: 1,109   Location: Fairhope, Alabama USA Thanks: 603 times Was thanked: 204 time(s) in 170 post(s)
Thanks for using my show as your screen capture sample! Here's the full show: Still learning vMix. Lots of fun! - Tom Sinclair / Streaming Idiots! (live Wednesdays at 3:45ish ET at www.EastershoreBroadcasting.com) (vMix USA reseller)
Groups: Guests
@ sinc747....when you get into vMix, it run rings around Vidblaster...far less CPU usage, smoother...but, vidblaster has the type of GUI I like...I was trying to get Mike to add a "T" bar to his mixer, and his attitude was rude and very unfriendly, so my friend dropped vidblaster, when we found vMix, and never looked back.....except for the unusual GUI of vMix, there is none out there in this range of mixer software that comes with such features, flexability, ease of use, and has such a friendly forum with quick response from its developers.....all that is really needed in my part from vMix, is a control surface, something like Blackmagic Livestream and such switchers.....and nothing will be able to touch it....I usually test all the updates on a simple low power PC (core 2 Duo, 2.0 gig, with 2 gigs or ram) with no problems...so my friend would just call me for my advice to update the system we use....
I watch your show here in Barbados when I am home, and I like it....missed it for the past couple of weeks due to work...keep the good work up.
sinc747 wrote:Thanks for using my show as your screen capture sample! Here's the full show: Still learning vMix. Lots of fun! - Tom Sinclair / Streaming Idiots! (live Wednesdays at 3:45ish ET at www.EastershoreBroadcasting.com) (vMix USA reseller) What I need to know is how to organize the entries marked red  Thank you!
Open the input's property page by double-clicking. Assign the input to a colout category and close the property page. Repeat for a few inputs to the same colour. Then, on the main screen, select the colour category on the leaft of screen. Only the selected input are shown. To re-order on the screen, left-click over the input and hold the mouse button down. Drag the input to a new position. Note you must drop it over another input not an empty space.
 1 user thanked ask for this useful post.
