jet
#1 Posted : Monday, October 13, 2025 5:56:00 AM(UTC)
jet
Was thanked: 25 time(s) in 23 post(s)
Just installed the new vMix 29.0.0.31 Beta and the latest BMD drivers (Desktop Video 15.1) and noticed the behaviour described in the topic subject.
The output (and input) card is BMD Micro (M.2).
This issue is repeatable.
My guess is that vMix gives not enough time to the I/O card to be initalized correctly before it goes ahead with other things.
#2 Posted : Monday, October 13, 2025 12:01:58 PM(UTC)
Moved this to Hardware Compatibility as we cannot replicate this and Decklink API behavior has not changed in vMix 29.
My guess is some kind of issue with that particular device or system.
jet
#3 Posted : Monday, October 13, 2025 5:33:02 PM(UTC)
jet
The weird thing is that when vMix quitted 1st time then the Output IS Awakened / initialized on exit.
jet
#4 Posted : Tuesday, October 14, 2025 8:10:28 PM(UTC)
jet
Really, really weird. Today vMix output worked right away, without the need to quit and re-run vMix.. (I did not yet update to the latest beta).
jet
#5 Posted : Tuesday, October 14, 2025 8:42:12 PM(UTC)
jet
Stopped working again.
Found this on the net:
https://weareatomic.com/lab/sdi-level-a-b/
Now changed the M.2 card to use SDI Level A and it seems to work more reliable.
jet
#6 Posted : Tuesday, October 14, 2025 9:48:10 PM(UTC)
jet
Now Output seems to work great with SDI Level A and latest vMix 29.0.0.32 Beta
jet
#7 Posted : Monday, October 27, 2025 8:27:58 PM(UTC)
jet
vMix initializes Output inconstantly.
When vMix is started directly or with a preset file it initializes Output differently than when if the preset is loaded manually after program start using "Open preset".
The initializon is done correcly when "Open preset" is used and wrongly (partially?) on vMix start resulting that the Output is not initialized = no program out on BMD Micro SDI out.
This is a huge problem when a preset is used and when the machine is set up to start up without human intervention.
It should be noted that this can be reproduced especially when no signal is fed to BMD Micro SDI IN when vMix starts.
