IP to Whitelist for licensing
Joined: 10/10/2025(UTC) Posts: 1  Location: LA Thanks: 2 times
Could someone confirm the IP required to license the software? We are on a closed network and will require the IP to be whitelisted in order to reach it for licensing. Thanks.
Joined: 2/9/2021(UTC) Posts: 35  Location: Oslo Thanks: 2 times Was thanked: 2 time(s) in 2 post(s)
You're probably better off emailing support@vmix.com for this. Can't find it publicly posted, and it is subject to change. From their vMix Call article: Quote:IP Addresses NOTE: vMix does not provide or list IP addresses of our servers as these can change at any time due to redundancy and security requirements. Therefore, if it is not possible to open the ports above in general on a restrictive firewall, vMix Call will not be able to be used. Yes, I know that's not the same thing, but it means that you're unlikely to get a post with it either. You may get it directly from support, though. I suggest considering buying a perpetual license instead of a subscription, that way you only have to activate it once instead of monthly.
 1 user thanked Andreas O for this useful post.
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: Andreas O  I suggest considering buying a perpetual license instead of a subscription, that way you only have to activate it once instead of monthly. Wouldn't it still verify with the licensing server every time it's launched? Otherwise, you'd be able to deactivate a device without impacting the ability to run the software.
 1 user thanked WaltG12 for this useful post.
