Feature Requests
MultiCorder – Record Audio Inputs & Choose Audio per Camera It
It would be great if MultiCorder could record audio inputs directly, and/or allow users to choose which audio input is recorded with each camera.
For example:
DeckLink 1 video with RØDECaster Mic 1 audio
DeckLink 2 video with RØDECaster Mic 2 audio
etc.
This would make vMix perfect for podcast and multi-guest setups where each camera needs its own mic ISO.
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
Originally Posted by: Charles P  allow users to choose which audio input is recorded with each camera That's literally how it works. You select the camera audio device when you add the camera to vMix. If you need to record a separate audio device from the one you selected, route the camera to an output, set that audio device to the relevant bus, and record that. As an ISO recorder, that's how the Multicorder works--it records the input or output with its designated audio source.
Feature Requests
