65 Pages«<636465
Tula3x3
#1281 Posted : Tuesday, April 8, 2025 4:12:13 PM(UTC)
Tula3x3
Russian Federation
good afternoon. is there a complete list of commands with a description of the actions?
MattGrover
#1282 Posted : Monday, April 28, 2025 7:15:02 PM(UTC)
MattGrover
I've got a bit of a recurring issue with UTC losing it's connection to vMix, it's on the same machine, local IP address (127.) for vMix, can't re-sync, and the other day when this happened, even after restarting everything, it still wouldn't connect, it started the day fine though.
Anyone got any ideas why this may be happening?
Cheers
Luis70
#1283 Posted : Monday, April 28, 2025 7:45:13 PM(UTC)
Luis70
Grenada
UTC seems to a bit troublesome since it is not updated of lately...I use Panel Builder which works much better, plus it is much easier to understand and set up ... you should give Panel Builder a try. ... plus it has a GUI that is more like a real hardware switcher...been using since it was launched, and do not use UTC anymore ...
NoemieM
#1284 Posted : Monday, July 7, 2025 11:31:32 PM(UTC)
NoemieM
Chircanu
#1285 Posted : Thursday, August 7, 2025 5:31:09 PM(UTC)
Chircanu
Congratulations @elgarf on the decision to continue this wonderful project that has made our work easier in our productions. This is the last update. However, I would like to make a small request, namely if it is possible to implement the change of colors from UTC for the rectangle in GT design. Thank you!
https://github.com/elgar...C/releases/tag/v07092025
Chircanu
#1286 Posted : Saturday, August 9, 2025 6:46:15 AM(UTC)
Chircanu
Chircanu
#1287 Posted : Wednesday, August 20, 2025 7:28:17 PM(UTC)
Chircanu
jojnkelli
#1288 Posted : Wednesday, October 1, 2025 11:01:06 AM(UTC)
jojnkelli
India
Elgarf advised using the SetImage script command or a list of image paths for item sources. He also suggested making a button that plays sound and links a hotkey for "+1" score with the button’s execute event, though it only works when scoring via the hotkey.
Guest (25)
65 Pages«<636465
