Feature Requests
Lock Inputs in Virtual Set
Joined: 10/26/2023(UTC) Posts: 1  Location: Melbourne
After creating a virtual set with many inputs (screens, cameras etc.) I would like a function to be able to easily lock and unlock an input so it cant be moved easily when a mouse glides over the preview or output window and touches something. Could be on the tile so by glancing at it you know it's locked and wont move or change by accident. Very handy for live productions with many people working on them.  padlock idea.png (78kb) downloaded 54 time(s).
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Same here, this is required because vmix doesn't or can't properly update scripts with input numbers, especially dynamic inputs. Just a lock all in place would be useful and any new input just goes at the end.
Joined: 11/23/2020(UTC) Posts: 227  Location: Wichita Thanks: 11 times Was thanked: 29 time(s) in 25 post(s)
Originally Posted by: SuperBill  Same here, this is required because vmix doesn't or can't properly update scripts with input numbers, especially dynamic inputs. Just a lock all in place would be useful and any new input just goes at the end. Don't write scripts using input numbers. The KEY field is unique for each input and doesn't change if the input get moved to a different number or even the Name of the input is changed. Only if an input is deleted and then added back would the Key change.
Where do you see this key field? Is it new? I'm on the latest and I don't see KEY field in the input settings, general or advanced.
Joined: 11/14/2012(UTC) Posts: 316  Location: Finland Thanks: 200 times Was thanked: 19 time(s) in 17 post(s)
Originally Posted by: SuperBill  Where do you see this key field? Is it new? I'm on the latest and I don't see KEY field in the input settings, general or advanced. Having the same question.
Thanks: 64 times Was thanked: 153 time(s) in 137 post(s)
Originally Posted by: SuperBill  Where do you see this key field? Is it new? I'm on the latest and I don't see KEY field in the input settings, general or advanced. You find them in the API, see: https://www.vmix.com/help28/DeveloperAPI.htmlThere are multiple ways to scripting. I prefer to give unique, telling names to the inputs in vMix, like "Scoreboard" instead of "scoreboard2025_v21.gtzip" and use these in the scripts, instead of keys/GUID. You can still move the input around, change it to a new version of the gtzip file, makes the script easier to understand when you haven't used it for a long time, and allows to use it for a completely different preset.
 1 user thanked dmwkr for this useful post.
Feature Requests
