NDI
Desktop Capture for vMix
新しいNotePCにDesktop Capture for vMixをインストールして起動しましたが、vMixアプリのNDIでは、このNotePCを認識しません。 どうしたら良いですか? Windows11 24H2 です。 ほかのNotePCを接続していますが、それは繋がっていることが確認できています。 どなたか分かる方があれば教えてください。
Thanks: 8 times Was thanked: 1 time(s) in 1 post(s)
do you see the vmix desktop capture from laptop 1 on studio monitor from NDI on laptop 2?
Joined: 11/23/2020(UTC) Posts: 249  Location: Wichita Thanks: 14 times Was thanked: 32 time(s) in 28 post(s)
Also check and make sure that the vMix machine and the NotePC machine are on the same IP Subnet, otherwise you need to have additional software running. So if your NotePC is running on a subnet that's used exclusively for Wireless connections while your vMix machine is on a subnet for hardwired systems NDI streams on each of those subnets are not visible outside of those subnets without running additional software to make them see each other (Look at NDI Tools for the software to make them see each other).
NDI
