Feature Requests
Add tittle transition in and out in shorcut
Joined: 9/30/2024(UTC) Posts: 12  Location: Cayenne Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Today, impossible to have a shortcut for tittle transition in and out. Because as usual, tittle start automatically transition with overlay in/out. But, sometimes, we need to start title in a different MIX an OUTPUT. Only shorcut could do it.  Capture.PNG (21kb) downloaded 46 time(s).
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Johann973  Today, impossible to have a shortcut for tittle transition in and out.
Only shorcut could do it Title is an input , try input controls
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Only shorcut could do it. From the help files: https://www.vmix.com/help28/Mix.htmlQuote:Overlays and Stingers
Overlays and Stingers can be used from the exiting 4 Overlay or 4 Stinger channels. To display on one or more Mix inputs, set the Mix setting for a shortcut to those inputs required, where 1 = the main output. Stingers will automatically cut all the Mix inputs the shortcut is assigned to at the stinger cut point.
Overlays and Stingers can be used from the exiting 4 Overlay or 4 Stinger channels. To display on one or more Mix inputs, set the Mix setting for a shortcut to those inputs required, where 1 = the main output. Stingers will automatically cut all the Mix inputs the shortcut is assigned to at the stinger cut point. Web page not available. I know that, but the problem is to start title animation in MIX 2 and not in MIX 1. Today, it's not possible. I created a virtual input from tittle with layer. A lot of time spent. A simple Transition in/out for a shortcut would be very more simple.
Link should be correct now: https://www.vmix.com/help28/Mix.htmlQuote: I know that, but the problem is to start title animation in MIX 2 and not in MIX 1. Today, it's not possible. I created a virtual input from tittle with layer. A lot of time spent. A simple Transition in/out for a shortcut would be very more simple.
Maybe I don't understand what you are trying to achieve, but I think you just have to configure your overlay shortcut for Mix 2, and it will only transition in on Mix 2. See screenshot.  shortcut.PNG (20kb) downloaded 13 time(s).Or do you want to have it on Mix 1 AND Mix 2, but want to use another Title animation (like Page1) only in Mix 2? Sure, this will not work.
Feature Requests
