gabriel.bordini
#1 Posted : Friday, June 6, 2025 7:17:17 AM(UTC)
gabriel.bordini
Brazil
I’m trying to improve the quality of a Zoom live session where I use vMix as my production hub. I control everything from one machine and avoid using Zoom's built-in "Share Screen" function. Instead, I switch scenes inside vMix and send the output to Zoom via the vMix Virtual Camera.
The goal is to keep things centralized and seamless — switching between camera, slides, and videos, using Picture-in-Picture when needed — and avoid Zoom’s Share Screen interface altogether.
The problem:
Even though I’m outputting 1080p from vMix, the Zoom participants receive a low-res image when I'm showing slides or detailed screen content. It looks like 360p or 480p. The text is blurry and hard to read. From what I understand, Zoom treats virtual camera feeds as webcam video, which is heavily compressed and capped in resolution unless specific conditions are met.
What I’ve checked or tried:
vMix output is 1080p 30fps
Good internet connection (10 Mbps upload+)
Zoom “Group HD” and “Enable 1080p” options turned on in the web portal
Currently using Zoom Pro
From my research:
Zoom limits video resolution unless you're on a Business, Enterprise, Webinar, or Zoom Rooms plan
Even then, you must request 1080p to be manually enabled by Zoom Support
Zoom prioritizes Share Screen over camera feeds when it comes to resolution and clarity
My question:
Has anyone successfully streamed high-quality slides and video into Zoom using only vMix and Virtual Camera, without needing a second machine or switching to Share Screen?
What Zoom plan did you use?
Did you find a workaround to force higher resolution for Virtual Camera?
Is it simply better to use Share Screen for text-heavy content?
Any tricks to make Virtual Camera output as clear as Share Screen?
Appreciate any real-world feedback. I'd like to keep everything controlled from one machine using vMix, but clarity is critical for the content I'm sharing.
Thanks,
Gabriel
knbPixels
#2 Posted : Saturday, June 7, 2025 12:00:58 AM(UTC)
knbPixels
You are correct that only certain plans allow for full HD video in a Zoom call. And you are correct that you have to request the feature. There are a few flags on the account backend that Zoom has to turn on/off to make it happen, even if you have the 1080 options in your account settings.
Regarding video vs screenshare, yes screen share will always be alittle bit sharper, because all sources in Zoom are a balance of frame rate and resolution, with camera sources leaning more towards frame rate, which makes sense because it's a camera, and shared screen leaning more towards resolution. If you use the Zoom for vMix plugin and connect that way, it likely will put the vMix video into Zoom at the same sort of quality you're seeing with the virtual camera, but it's an option worth checking.
If the quality is as bad as you're describing, that's a different story. You can check the resolution from another machine, by pinning that virtual camera to your other computer's meeting window, and going into the Statistics part of the Zoom menus, and seeing what actual resolution is coming through. Be aware that a lot of times even if HD is truly enabled for the meeting and account, there still has to be a "demand" for HD from somewhere for it to kick in. Someone needs to have the camera window of your vMix virtual camera at a large enough scale to demand it be 720p or 1080p. I have taken the step in the past to dedicate a machine to pin a participant just to force that larger view and HD quality.
If you only need HD quality for single events and not long term, I believe Zoom Events temporary licenses come with that feature. I think they've gone to tiers with their resolutions, so a Pro account can do 720p, but not 1080p. And a Business or Enterprise account can do 1080p, but I'm not 100% on that. I will say though in my many years of experience with Zoom and event/production, that the difference between 720p and 1080p in Zoom is pretty small, especially when it's a camera source.
To answer your other questions, Camera sources will never be as sharp as screen share sources, but can be pretty close at 720 or 1080.
If you're sharing text, then yes...screen share will always be the sharpest looking option. If you don't like the idea of PPT or Keynote etc in use, consider a Stream deck with Companion running and controlling the computer feeding the slides in. It makes things very easy.
tli04
#3 Posted : Wednesday, September 17, 2025 12:07:36 PM(UTC)
tli04
Hi Gabriel,
Were you ever able to figure out a solution to your issue? We're in the same position right now, trying to get something other than 360p for webinars. For us it seems to only start acting up with there are >100 people in the webinar.
I chatted with Zoom support get everything established, but still running into issues.
knbPixels
#4 Posted : Friday, October 3, 2025 11:41:32 PM(UTC)
knbPixels
Originally Posted by: tli04 Go to Quoted Post
Hi Gabriel,
If it's just slides or graphics with no audio you are trying to insert into the webinar you could try having vMix spit out an NDI feed, open that feed up with NDI Studio Monitor, then screen share that into Zoom. When you use a camera source in Zoom, Zoom prioritizes frame rate, because it's a camera. When you screen share it prioritizes resolution for clarity. Now that may not fix your issue of not being able to get more than 360p or 640p, but it could help you anyway within that limitation.
Also always check your webinar extra settings before you launch it, and your account settings, to make sure 1080 is enabled, and as mentioned before you need to be on a business account or higher I think, to get Zoom support to turn on 1080 or at least HD to get 720p
