Joined: 5/1/2020(UTC) Posts: 33  Location: Tennessee Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hey All! I was curious if anyone has a simple scripting solution to continuously check whether or not a data source is positive and if it's not, take the abs of it and replace the data feed with the abs of that number. I've tried to use 'newnumber = math.abs(oldnumber)' and then using 'API.Function("SetText",Input:=scoreboard , Value:=newballon, SelectedName:="Ballon.Text")' but running that in a continuous script seems to be producing no solution. The Context is I have a scoreboard sending Vmix a JSON data stream in American Football. Depending on field position the ball location, the scoreboard will send a negative number for field position. I've been trying to find the right set of commands to right a script but it seems to evade me. Thanks in advance, and I did look at the scripting for dummies and didn't see any math examples.
Kris
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: MSFTGuruGuy  Hey All! I was curious if anyone has a simple scripting solution to continuously check whether or not a data source is positive and if it's not, take the abs of it and replace the data feed with the abs of that number. I've tried to use 'newnumber = math.abs(oldnumber)' and then using 'API.Function("SetText",Input:=scoreboard , Value:=newballon, SelectedName:="Ballon.Text")' but running that in a continuous script seems to be producing no solution. The Context is I have a scoreboard sending Vmix a JSON data stream in American Football. Depending on field position the ball location, the scoreboard will send a negative number for field position. I've been trying to find the right set of commands to right a script but it seems to evade me. Thanks in advance, and I did look at the scripting for dummies and didn't see any math examples.
Kris
First off spelling and writing commands when scripting(coding) is very important commands to right a script ==> commands to write a script When it comes to a script you don't mention how you are retrieving the value. In vMix scripting using vb.net one usually has to retrieve datasource data through a title (simplest way). Do some logic or conversion on that and like in this case send to your title And put the whole thing in a loop for repeated checking Code:Do While true
Dim text as string = Input.Find("title.gtzip").Text("Headline.Text")
Dim value As Integer = Integer.Parse(text)
Dim abs1 As Integer = Math.Abs(value)
API.Function("SetText",Input:="title.gtzip" , SelectedName:="Description.Text" , Value:=abs1)
Sleep(500)
Loop
' or for short
Do While true
API.Function("SetText",Input:="title.gtzip" , SelectedName:="Description.Text" , Value:=Math.Abs(Integer.Parse(Input.Find("title.gtzip").Text("Headline.Text"))))
Sleep(500)
Loop
Thanks Doggy Thanks for catching that typo of a fifth-grade homophone while I was juggling a conversation with my daughter about what was right and wrong to write in a birthday card. But you make a very good point, not only are spelling and writing commands important, equally is grammar.
spelling and writing commands when scripting(coding) is very important ==> spelling and writing commands when scripting(coding) are very important can also be very important.
This has two rules depending on the part of the world you are educated from; however, because spelling and writing are joined, we need to use the plural subject instead of the singular. It might feel better pairing these thoughts into a single combined idea; however, "are" is correct because they are two separate skills were referenced, but this is where the use of "is and "are" becomes dependent on the location where the education curriculum was initiated. :) In either way, it highlights the importance of leading with the right tone and it doesn't come across as a lecture or pontification as I'm sure this post has done already, so I'll apologize because I appreciate you. You probably would have rather just read the following and moved on.
I really appreciate all your help over the years; it's been so wonderful to have someone willing to support a worldwide community as a volunteer like you have. Again, you've expressed your masterful knowledge of this platform, and I know you have had countless thankyous, but I'll add one more. Thank you! I'll give this a try this morning and I'm sure (as most of your rescues) it will resolve the issue. I mentioned it was a JSON data feed leveraged in a title. I believe the common way for vMix to ingest a JSON data feed is by declaring it in the Data Sources Manager & making the association in the title editor. That was my mistake for assuming that's what anyone else might assume how the data is retrieved. Thanks again for the help and the hopeful read of the first part of this reply with a little jocular tone.
Kris
Originally Posted by: MSFTGuruGuy  Thanks again for the help and the hopeful read of the first part of this reply with a little jocular tone.
Kris Of course I did as it's not my first (native) language ;-) BTW I often use extra hidden fields in my titles exactly for such purposes (sort of reproces or customize such data for display)
