KerryDP
#1 Posted : Monday, September 8, 2025 9:22:13 AM(UTC)
KerryDP
New Zealand
Is there a way to trigger (via scripting) a change in SRT presets? In my situation, I'd like to use one destination IP address when the computer is on the internal network, and a different IP address when the computer is on a remote location (and connecting to the network externally). Changing the IP by a script would be faster and easier than having to re-type the IP/port info for all four SRT outputs.
ckvideo
#2 Posted : Thursday, September 18, 2025 8:56:29 AM(UTC)
ckvideo
Germany
as far as I know up to vMix 28 there is unfortunately no way to reach the SRT outgoing parameters via scripting or API. This is a pity, since there is currently no automation possible on this aspect of vMix. If you look in the feature request forum, there are some requests for better SRT stream handling. Maybe you can support this by upvoting it: https://forums.vmix.com/...--set-Mode--IP-and-Port. At IBC, I discussed this with the friendly folks from vMix, we'll see if it makes it on the roadmap.
Currently this is a roadblock in use case were vMix acts like an automated signal switcher for streams.
