lbgaus
#1 Posted : Wednesday, September 3, 2014 11:24:56 PM(UTC)
lbgaus
Hi Martin,
It would be nice to have an option to refresh a Title/XAML input using the right-click menu. Currently, going to Settings and clicking change will assign a new GUID each time the input is changed, making it necessary to update all API commands to affect the Title/XAML Input whenever we make a layout change to the XAML file in the Title Designer.
Thank you!
#2 Posted : Thursday, September 4, 2014 8:50:44 AM(UTC)
Can you try the latest vMix 14 preview just posted?
http://forums.vmix.com.au/default.aspx?g=posts&m=11986#post11986
The GUID/Key changing is a bug, which I have now fixed.
lbgaus on 9/4/2014(UTC)
puruzio
#3 Posted : Monday, May 4, 2020 2:56:24 AM(UTC)
puruzio
Is there a way to refresh an existing title input (e.g., via right click menu as the original question above suggests) without having to remove and re-add?
It's a pain to go through that process every time a small change is made to the template. Thanks.
#4 Posted : Monday, May 4, 2020 3:58:07 AM(UTC)
Original was 6 years ago, when was the last time you updated and checked the right click options or the restore button?
