Feature Requests
Feature of toggle colors in
Joined: 3/13/2020(UTC) Posts: 38  Location: Stockholm Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hi We got alot of graphics made in GT-Designer and we need to be able to toggle signs But we are just able to toggle Text and Picture but not Color that should be our Rectangels behind the text. So right now we just could take away text and pictures, but the rectangels (xxxxx.Fill.Color) still showing. I created a film about my issue I want to be solved
Joined: 12/27/2012(UTC) Posts: 5,527  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Salleman  Hi We got alot of graphics made in GT-Designer and we need to be able to toggle signs But we are just able to toggle Text and Picture but not Color that should be our Rectangels behind the text. So right now we just could take away text and pictures, but the rectangels (xxxxx.Fill.Color) still showing.
You could use pages in your title one page has the image (and other items) visible the other page has it hidden. Use a fast fade animation to show/hide the item when the page changes within the title Call the page with the shortcut TitleBeginAnimation Value "Pagex" where x is the page number
Originally Posted by: doggy  Originally Posted by: Salleman  Hi We got alot of graphics made in GT-Designer and we need to be able to toggle signs But we are just able to toggle Text and Picture but not Color that should be our Rectangels behind the text. So right now we just could take away text and pictures, but the rectangels (xxxxx.Fill.Color) still showing.
You could use pages in your title one page has the image (and other items) visible the other page has it hidden. Use a fast fade animation to show/hide the item when the page changes within the title Call the page with the shortcut TitleBeginAnimation Value "Pagex" where x is the page number It could absolutely be a solution normally, but this is a scoreboard with many different fields that are toggled on and off and it would be a nightmare to handle all the variations via pages in GT Since Text and Image can be toggle on and off, I think color should also be able to do the same since they are available as editable in Title
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: Salleman  It could absolutely be a solution normally, but this is a scoreboard with many different fields that are toggled on and off and it would be a nightmare to handle all the variations via pages in GT Since Text and Image can be toggle on and off, I think color should also be able to do the same since they are available as editable in Title Just to keep it less complex, in addition to doggy's suggestion you can also put the "Empty Goal" part in a 2nd title with pages and layer it on the scoreboard input.
Originally Posted by: dmwkr  Originally Posted by: Salleman  It could absolutely be a solution normally, but this is a scoreboard with many different fields that are toggled on and off and it would be a nightmare to handle all the variations via pages in GT Since Text and Image can be toggle on and off, I think color should also be able to do the same since they are available as editable in Title Just to keep it less complex, in addition to doggy's suggestion you can also put the "Empty Goal" part in a 2nd title with pages and layer it on the scoreboard input. Of course, but it would not be complex if Color/rectangle also was toggleble :-)
 Image.png (9kb) downloaded 16 time(s). Image.png (9kb) downloaded 16 time(s). Text.png (11kb) downloaded 16 time(s).Originally Posted by: Salleman  Originally Posted by: dmwkr  Originally Posted by: Salleman  It could absolutely be a solution normally, but this is a scoreboard with many different fields that are toggled on and off and it would be a nightmare to handle all the variations via pages in GT Since Text and Image can be toggle on and off, I think color should also be able to do the same since they are available as editable in Title Just to keep it less complex, in addition to doggy's suggestion you can also put the "Empty Goal" part in a 2nd title with pages and layer it on the scoreboard input. Of course, but it would not be complex if Color/rectangle also was toggleble :-) I meen, you are able to toggle Text and Images, but not Color. Why?  Color.png (7kb) downloaded 17 time(s). Image.png (9kb) downloaded 16 time(s). Text.png (11kb) downloaded 16 time(s).
Feature Requests
