Beta Discussion
OMT integration in settings GUI
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Hi vMix team Thank you for the new preview release! As a heavy NDI user, I'm excited to see how OMT will develop. That's why I first looked into the new ndi/otm settings. Output configuration in settings: - I like the decision that every Output 1-4 has got there own protocol On/Off button "NDI", "OMT"and "SRT". Now we have a simple overview which protocol is really enabled or not!
Opening "Output settings": - I like the new section structure "OMT Settings" and "SRT Settings".
- What's not that clear to me (and probably new users as well): Are the configurations above "OMT Settings" only for NDI? Or valid for the other sections as well? If the last, probably a section "General" on top would help to better understand.
- Or are some settings only valid for NDI, for example the "20db Boost"? Then a section "NDI" would make sense as well.
- I think a clearer presentation could also reduce support questions.
The section "SRT Settings" has still a checkbox "Enable SRT" (which is linked to the Output configuration On/Off button). The new "OMT Settings" section is missing this checkbox. I would suggest, for consistency reasons, to remove the SRT Enable checkbox there. Thank you very much for checking my suggestions. Best regards, Patrick
Joined: 1/13/2010(UTC) Posts: 5,320  Location: Gold Coast, Australia Was thanked: 4720 time(s) in 1617 post(s)
The settings are described at the bottom of this page in the help file: https://www.vmix.com/help29/NDIandOMT1.htmlThe SRT toggle button on the outputs page opens up this window if SRT has not yet been configured, so the checkbox is needed. OMT does not require settings to be configured prior, so this is why it does not have a checkbox.
Beta Discussion
