I am using a ticker to display scores for multiple matches, if one of the scores change (updating the ticker text) the ticker restarts leaving a blank screen waiting for it to slowly scroll across. If there was a check box option to say "continue on data change" would look much better.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: CueballTV  I am using a ticker to display scores for multiple matches, if one of the scores change (updating the ticker text) the ticker restarts leaving a blank screen waiting for it to slowly scroll across. If there was a check box option to say "continue on data change" would look much better. In Ticker Settings change type to Add https://www.vmix.com/help28/GTTitleDesigner.html
Tried that first, doesn't update at all. Maybe something to do with how the data is updated - via excel data source
