michaelthomasbrennan
#1 Posted : Monday, August 18, 2025 9:24:01 PM(UTC)
I have a two box comp on a gfx backgound. The right hand box is a single source input, the left hand box is a blank input with a camera green screen and a keyed background in two layers which are flattened OB 1 and Pres 1 box over gfx bgd.png (733kb) downloaded 54 time(s). Pres 1 layering.png (1,555kb) downloaded 60 time(s).. If I have the single source input in the preview channel the new merge effect works. If I have the comp green screen input in the preview channel the new merge effect does not work and I just get a fade/dissolve
#2 Posted : Monday, August 18, 2025 10:57:27 PM(UTC)
Was thanked: 4711 time(s) in 1615 post(s)
Moved this to general discussion, as there have been no changes to Merge in vMix 29, so you may need to explain in more detail.
If it is fading its usually due to flattened layers or some other setting along those lines.
