Joined: 1/25/2019(UTC) Posts: 308  Thanks: 17 times Was thanked: 79 time(s) in 60 post(s)
I’ve built a small OMT Player for Windows that lets you receive OMT streams (video + audio) directly over the network. The app is based on the official libomtnet SDK (thanks Martin) and uses NAudio for audio playback. Features -automatic discovery of OMT sources in the local network -video rendering in a window (BGRA) -audio playback (48 kHz, stereo) -simple UI with Refresh / Connect / Disconnect Download & Installation Download ZIP-Unzip into any folder -Run OMTplay.exe – no setup required Notes: If no source is detected (while one is running), please check your Windows Firewall. In my case, disabling the firewall or creating a rule for omtplay.exe solved the issue. Tested with vMix (default OMT settings) – the player receives around 50–70 Mbit/s. Runs smoothly even over WiFi6 on my setup.
