Beta Discussion
GO Action shortcut does not handle moved inputs (FIXED)
Joined: 2/23/2023(UTC) Posts: 80  Thanks: 26 times Was thanked: 19 time(s) in 5 post(s)
Version: 29.0.0.19
1. Create a new Preset 2. Add two color inputs 3. Configure Input 2's Go button to be the shortcut: Function: Cut, Input: 2 Colour. Note: Assign Shortcut to Input Number is NOT checked 4. Reorder Input 2 to Input 1's position 5. Click Input 1's GO button
It was expected that the GO button operated on the Input GUID, not the Input number. Inspecting Input 1's GO button shortcut shows the Input on the Cut Function is assigned to Input 2.
Beta Discussion
