wolfbytes
#1 Posted : Thursday, July 31, 2025 10:36:07 AM(UTC)
wolfbytes
Looking to upgrade the GPU on one of my systems, currently running a 8GB 4060 Ti, while it's relatively unbalanced with a 9950x CPU. System is moving to become our primary sports box. Has a Decklink Quad 2.
Typically we run 3 or 4 SDI cams, 2 or 3 srt camera feeds, and an NDIHX ptz camera feed.
I normally use replay for 4-6 cams. Broadcast out to an external encoder most of the time via SDI.
I am trying to decide if a 5070 Ti would be sufficient or if I should try to push the budget to something like an RTX 4000 Ada if that would give me significant advantage in my workflow I'll try to go for that.
Any feedback here or some GPU I'm missing?
Edit: Also should add I do use Vmix Calls and some NDI outs to feed talent/cams.
Kayo33
#2 Posted : Friday, August 1, 2025 4:07:57 AM(UTC)
Kayo33
Was thanked: 18 time(s) in 14 post(s)
RTX 4080 Super (or 5080 if budget allows it)
Roy Sinclair
#3 Posted : Monday, September 22, 2025 12:40:03 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
Is there a performance problem with the current GPU? Is your Render Time getting above 8ms for 60FPS or 15ms for 30FPS?
Because if it isn't you're unlikely to see an improvement, you'll just end up spending a lot of money for performance that's unlikely to improve.
I say that because I'm running five cameras (no instant replay) on a GTX 1060 TI which is a long way down the curve from that 4060 Ti.
You might do better to look at putting the instant replays onto a dedicated M.2 NVME SSD if they are a problem point.
However, before you spend anything. Find out what your bottleneck is and if you don't have a bottleneck then don't bother changing anything. If you do have a bottleneck, concentrate on it.
