Systems
Off the shelf PC for 16 Channel SDI system
Joined: 3/29/2020(UTC) Posts: 104  Thanks: 20 times Was thanked: 2 time(s) in 2 post(s)
Hi all,
Been away from vMix for a little while but needing to build a system capable of at least 16 SDI In/Out channels. Will either be using 2x Decklick Quad2 or AJA Corvid 88 cards.
Happy to install the GFX and IO cards my self but wanted everything else to be pretty much as turn key as possible to save time.
I dont need to do any more than 2 replay channels at most, I just need the SDI IO capabilities of the Obtanium build rather than replay abilities.
About to start scouring the web for ideas but though I'd ask here first
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
What's your budget? And do you expect to ever expand the system in the future?
If you have lots of $ and only care about time, contact Dell and ask about a workstation with an Ampere series GPU.
If you want future expandability, you may need to build something. Workstation grade is pretty much the main area you'll find a motherboard and CPU with enough PCIe lanes to really have room for expansion.
Thanks for the reply.
Money not really a factor for this build. Main needs are reliability and number of channels. To be honest, most projects this machine will be used for are just 4-5 ins and 2-4 outs so the 16 channels I have specified already allows for growth and flexibility.
Joined: 10/20/2023(UTC) Posts: 166  Thanks: 3 times Was thanked: 18 time(s) in 14 post(s)
Given the real need, Socket 2066 might be sufficient x299 motherboard + i9-10980xe
or platform AM5 + Ryzen 9
and invest later in a larger configuration if really necessary
12 i/o HD
Ryzen 9 9950x = 24 cpu lanes MSI Meg x670e Ace = pcie slots (x8/x8/x4) + M2 slot (x4) 2 x 32gb DDR5 M2 pcie 5.0 x4 (M2 cpu lanes x4) M2 pcie 4.0 x4 RTX 4080 Super OC (pcie cpu lanes x8) decklink quad 2 (pcie cpu lanes x8) decklink duo 2 (pcie cpu lanes x4)
16 i/o HD
i9-10980xe = 48 cpu lanes Asrock x299 Taichi CLX = pcie slots (x16/x16/x8/x8) 4 x 16gb DDR4 Asrock Ultra Quad M2 Card + 1/2/3 or 4 x M2 pcie 3.0 x4 (cpu lanes x16) RTX 4080 Super OC (cpu lanes x16) decklink quad 2 (cpu lanes x8) decklink quad 2 (cpu lanes x8)
12 i/o 4K or 24 i/o HD
i9-10980xe = 48 cpu lanes x299x Aorus Master or MSI Creator x299 = pcie slots (x8/x8/x16/x8) + M2 slots (x4/x4) 4 x 16gb DDR4 M2 pcie 3.0 x4 (cpu lanes x4) M2 pcie 3.0 x4 (cpu lanes x4) RTX 4090 (cpu lanes x16) decklink 8k pro / quad hdmi or quad 2 (cpu lanes x8) decklink 8k pro / quad hdmi or quad 2 (cpu lanes x8) decklink 8k pro / quad hdmi or quad 2 (cpu lanes x8)
Xeon W7-2575x = 64 cpu lanes Asrock WS 790 = pcie slots (x16/x8/x16/x8) + M2 slots (x4/x4/x4/x4) 4 x 32gb DDR5 RDIMM M2 pcie 5.0 x4 (M2 cpu lanes x4) M2 pcie 5.0 x4 (M2 cpu lanes x4) M2 pcie 5.0 x4 (M2 cpu lanes x4) M2 pcie 5.0 x4 (M2 cpu lanes x4) RTX Pro 5000 Blackwell (cpu lanes x16) decklink 8k pro / quad hdmi or quad 2 (pcie cpu lanes x8 on pcie slot cpu lanes x16) decklink 8k pro / quad hdmi or quad 2 (pcie cpu lanes x8) decklink 8k pro / quad hdmi or quad 2 (pcie cpu lanes x8)
Systems
