jet
#1 Posted : Monday, July 21, 2025 9:22:59 PM(UTC)
jet
Was thanked: 15 time(s) in 13 post(s)
Recently encountered some issues with Input Position altering/reset.
Example when Reset button is pressed the value is not reset or when altering the value slider the value is not updated..
This issue has happened at least with the Rotate field/slider and Pan X/Y.
I assume this is caused by some kind of floating point (rounding, value converting, foating point precision) issue.
#2 Posted : Monday, July 21, 2025 11:24:30 PM(UTC)
Was thanked: 4571 time(s) in 1581 post(s)
In order to investigate further, please provide step by step instructions on how to replicate the issue.
In my brief tests I am not able to trigger the issue, so there may be a specific step needed to trigger the issue.
Thanks,
jet
#3 Posted : Tuesday, July 22, 2025 12:22:27 AM(UTC)
jet
Thanks,
Hi Martin,
To me it seems that it happens when one manually fine adjusts the values by changing some of the decimals. This is only my assumption of the cause.
One time even the slider went in to a disabled state.
vMix 28.0.0.42
jet
#4 Posted : Thursday, July 24, 2025 10:47:25 PM(UTC)
jet
Here is a value that was displayed in one of the fields when the problem occured earlier:
-5,960464E-08
