Sadly there is no direct command in Companion to adjust (increase/decrease) the HeadphoneVolume. Is there anyway to use the SetHeadphonesVolume function for this?
Can't get it to work...
Thanks!
Joined: 4/30/2025(UTC) Posts: 2  Location: San Francisco Thanks: 2 times
I don't know if you got an answer, but I have the same question.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
 1 user thanked Henny for this useful post.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
For increasing (by 1) run the custom command: Code:SetHeadphonesVolume Value=%2B%3D1
For decreasing (by 1) run the custom command: Code:SetHeadphonesVolume Value=%2D%3D1
 2 users thanked dmwkr for this useful post.
Thanks for the tip! I’ll give it a try.
