Joined: 9/3/2021(UTC) Posts: 7  Location: LONDON Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
It would be great if we could sit borders on top of layers instead of around. Another great feature to have would be to put another input, such as an image, as a border or the ability to set a transparent border so it shows the image layer behind it
Joined: 12/27/2012(UTC) Posts: 5,451  Location: Belgium Thanks: 311 times Was thanked: 1006 time(s) in 830 post(s)
Originally Posted by: Harness  It would be great if we could sit borders on top of layers instead of around. Another great feature to have would be to put another input, such as an image, as a border or the ability to set a transparent border so it shows the image layer behind it You do realise most of your request is allready possible/available since forever ?
Originally Posted by: doggy  Originally Posted by: Harness  It would be great if we could sit borders on top of layers instead of around. Another great feature to have would be to put another input, such as an image, as a border or the ability to set a transparent border so it shows the image layer behind it You do realise most of your request is allready possible/available since forever ? Which part then? Borders sit around layers, not over. The only option I see for borders is a colour picker.
