We have a Studio PC that does not load into 4k Projects anymore. Vmix version is 28.0.0.42, Win 11 on latest 24H2.  Bild (8).png (18kb) downloaded 30 time(s).As far as i can tell, this seems to be an issue for a wide variaty of programms reagrdig the RAM, but we tested our ram and still the Problem persists. Does anyone has an idea of whats going on? Curios is, that the error does not always show, sometimes vmix just shuts down instantly without any warning, and it does that also only in some Projects, others seem to run fine? (Most of our projects are copies of one base project, that is just altered for individual customers) System Specs: CPU 13700k (no Overclock) GPU rtx4070 (no Overclock) RAM 2x 32GB (5600 MHZ xmp active)
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
It could be that your CPU is one of those that slowly destroys itself. The symptoms you describe are an indication of this.
