TL68
#1 Posted : Tuesday, September 12, 2023 1:09:14 AM(UTC)
TL68
Sweden
Hi!
If I understand correctly vMix call runs in the callers browser on either a computer or smartphone.
Regarding vMix call on smartphones I wonder if external USB-C and Lightning microphones are supported on both Android and iOS devices.
I have in other systems experienced that this can be an issue with browser based interfaces on smartphones.
I am especially interested in wether Röde Wireless GO II and iRig HD2 microphone systems work well with vMix call.
Thanks in advance for any input on this!
elvis55
#2 Posted : Tuesday, September 12, 2023 4:23:32 PM(UTC)
elvis55
Switzerland
mavik
#3 Posted : Tuesday, September 12, 2023 5:49:57 PM(UTC)
mavik
I would try https://advanced.vmixcall.com/
There you should be able select the mic.
TL68
#4 Posted : Tuesday, September 12, 2023 11:11:20 PM(UTC)
TL68
Sweden
Thanks!
Can confirm that the Irig HD2 lightning mic works with the advanced vmix call page!
It´s not totally smoth (needed reconnect on every new call connection for the lightning mic to activate. But almost good enough :-)
drawem
#5 Posted: : Tuesday, July 1, 2025 9:57:31 PM(UTC)
drawem
Germany
Unfortunately, we're currently unable to use any wired microphones, neither the iRic 2 nor the Sennheiser HD2.
Can anyone help with what might be causing this?
drawem
#6 Posted : Tuesday, July 1, 2025 10:13:01 PM(UTC)
drawem
Germany
According to Apple Support, vMix has to do some research on this, since WebRTC doesn't come from them either.
nikosman88
#7 Posted : Wednesday, July 2, 2025 6:58:46 AM(UTC)
nikosman88
Greece
https://forums.vmix.com/...al-microphones-in-iOS-17
This has been allready discussed. Dont wait soon a solution.
